node-red-contrib-pushover 0.2.0
A Pushover API wrapper for Node-RED
npm install node-red-contrib-pushover
A Pushover API wrapper for Node-RED.
Supports rich notifications and watch glances.
npm
Required Inputs
  • msg.payload(required): The message of the notification, supports a few html tags
Optional Inputs
  • msg.topic: This will be used as the title of the notification if Title is not set
  • msg.image: The URL of the image in notification. Local file path or http(s) url
  • msg.url: Can add an url to your notification
  • msg.url_title: Can set the title of the url
  • msg.priority: -2/-1/1/2, see explain
  • msg.device: Default for all device if not provided. Separated by a comma
  • msg.sound: Name of the notification sound, see the list
  • msg.timestamp: An unix timestamp to specific the date time of your notification
See Pushover.net for more details.
Pushover Glances
With Pushover's Glances API, you can push small bits of data directly to a constantly-updated screen, referred to as a widget, such as a complication on your smart watch or a widget on your phone's lock screen.
Available Inputs
  • msg.payload: This will be used as the title if Title is not set
  • msg.text: The main line
  • msg.subtext: The second line
  • msg.count: The number
  • msg.percent: The progress bar/circle
  • msg.device: Device name, default for all
Version: 0.2.0
Updated 7 years, 7 months ago
Rating: 5.0 6
174 in the last week
  • pushover-keys
  • pushover api
  • glances
  • pushover
  • notification
